Urgent redirection help required please...
Please can someone help me redirect my yola site (www.communitysupportnetwork.yolasite.com) to my new site - www.communitysupportnetworkfiji.org.
This is the second time I have asked now.
Many thanks for your swift response.
Kirsty
Photo of kirsty Barnby
kirsty Barnby
  • 6 Posts
Photo of Brandon
Brandon
  • 243 Posts
  • 33 Reply Likes
Hi Kirsty.
I'm sorry that your query went unnoticed the first time. Redirecting will be quite easy, and all you need is some code. On your .yolasite version of your website, insert an HTML widget, and paste the following code:
<script type="text/javascript">
window.location = "http://www.communitysupportnetworkfiji.org/"
</script>
The user will be automatically redirected to your new website! Simple as that. Please let me know if you have any trouble, or if you need more detailed instructions.
Regards,
Brandon
Sanja
Hello Kirsty,
I apologize that this post was missed. I hope that Brandon's suggestion helped.
Please let us know if it does not.
kirsty Barnby
  • 6 Posts
Hi,
Thanks for getting back. I have tried the suggested but the icon 'optimising images' comes up and doesn't go a way. Basically is crashes when I do it. The home page of my new site does appear though so I know the html was correct.
Can someone help me or even better, do it for me?
Thanks,
Kirsty
Sanja
Hello Kirsty,
I have set this up for you. Currently the redirect code is set for 5 seconds to allow time for you to determine if the redirect code is correct. We can then shorten the redirect time.
kirsty Barnby
  • 6 Posts
Hi,
O.K. All is good, would you mind shortening the time as much as possible?
Many thanks.
Kirsty
