Using Yola Pro credit when purchasing a premium template
I have the Yola Pro membership and have not yet used my $29.95 premium template credit. If I use one of the premium templates that cost less than that amount, do I still have a credit for the remaining amount that I could use on a second premium template?
Photo of Keara
Keara
  • 325 Posts
  • 14 Reply Likes
  • assuming that the answer is yes!
Photo of Monique
  • 6294 Posts
  • 446 Reply Likes
Hi Keara
This is a good question! Thanks for asking. Basically it is a template credit that can be used on any template regardless of the price (although the average cost is $29.95).
So you could select a more expensive one or a cheaper one. If you buy one worth less than $29.95 the remaining amount does not carry over to your next template purchase. So choose wisely :)
Photo of Margie
Margie
  • 286 Posts
  • 25 Reply Likes
Following up on that, Keara, could the premium template then be used on just one or all of our sites on the same account?
Thanks
Photo of Keara
Keara
  • 325 Posts
  • 14 Reply Likes
Margie, my understanding is that the purchaser can use the premium template on all of his or her sites. You'll want something firmer than that, but I'm pretty sure that's correct.
Photo of Monique
  • 6294 Posts
  • 446 Reply Likes
Hi Margie
Keara is absolutely correct. You can use the premium style on all the sites in your account. Pretty good deal, isn't it? :)
Photo of Margie
Margie
  • 286 Posts
  • 25 Reply Likes
Yes, a very good deal. Now, how to decide... :)
