Web page maker - upload to yola
  • Updated 7 years ago
I've created another page with web page maker and would like to upload it to my yola page, how can I do it?
Photo of Toma
Toma
  • 1 Post
Photo of Francois
Francois, Employee
  • 282 Posts
  • 19 Reply Likes
Hi Toma,
With Yola Silver, you can upload a .HTML file into the File Manager, but it is not easily possible make this .HTML an actual page on your top level navigation. For a page to work in Yola, it needs to be built using the Yola Widgets.
But, one way to make the .HTML file create a top level page on your navigation would be to cause your menu link to open the file in the File Manager, but this will require adding some HTML to your page.
Here's what you need to do:
  • Create a new page with the name of the site you want to link to.
  • Drag and drop an HTML Widget onto your page and paste in this code:
  • <meta http-equiv="refresh" content="2; url=resources/file.htm">
  • "2" is how many seconds it waits before it redirects - you can change this number. Once you add this code to your page in the Site Builder it will cause the Sitebuilder page to redirect as well.
  • "url" is the URL it redirects to, so, replace the URL in the above tag with the one for the site you want to link to which would be: http://mysite.com/resources/file.htm (substituting your information).
  • Another option is that you can link to your .HTML file and it would open like any other file does. The reference for the .HTML file the link would look like this: http://mysite.com/resources/file.htm
    To create a link in a Text Widget:
  • Drag a Text Widget onto the page
  • Type the text you want to be the link
  • Click on the Link Editor icon on the Edit Toolbar
  • Choose the file from your File Manager
  • That link will now link to your .htm file in the File Manager.
    You could also add it to the page using the File Widget and it would open as any other file does. The File Widget is located on the Sidebar. When you drag it onto your page you will be able to choose to add the file from your File Manager or from your computer.
    Please let us know if you have any trouble with this.
    Photo of Fagun Rain
    Fagun Rain
    • 2 Posts
    can i upload html file on free account
    Photo of Francois
    Francois, Employee
    • 282 Posts
    • 19 Reply Likes
    Hi Fagun Rain,
    If you are using Yola Free, it is possible to add HTML and Javascript snippets with our HTML Widget. However, it is not possible to upload .html or .js files to the File Manager. Unfortunately, we have been forced to restrict these uploads for security reasons, as internet criminals use this as an easy loophole to create phishing sites.
