When will Yola fix the bug in its rendering engine?
  • Updated 7 years ago
The bug adds a blank line when it encounters an unordered list closure i.e. .
Photo of David Gelperin
David Gelperin
  • 2 Posts
Posted 7 years ago
Photo of Laura Thomas
Laura Thomas
  • 4536 Posts
  • 211 Reply Likes
Hi David,
It sounds like your inquiry is incomplete, were you gong to include an example? That would be helpful as I'm not sure I'm familiar with the error you are reporting.
If you want single spacing in you Text Widget, select shift + enter/return. Please let me know if I have misunderstood your question.
David Gelperin
  • 2 Posts
I do NOT want any blank spaces to appear after an embedded list. That is what is happening now. I have 3 levels of embedding ending with 3 unordered list closures which is generating 3 blank lines (that I do not want).
According to HTML info, a list closure should not generate a trailing blankline -- as happens when you close a paragraph i.e. .
Photo of Gop
Gop
  • 7473 Posts
  • 2115 Reply Likes
Hello David,
if you add a CR/LF after each li closure then a blank line will be added. If you continue on after the closure new text is added on the following line. Not sure if this is w3c compliant or not? There may also be another aspect of browser used as the editor.
