Widgets problem
  • Updated 10 years ago
Hi admin..
I have some problem with building my site..
I have put some widget on my site.After i put the widget and publish it, the bottom of the widget have "Get widget"..
I've already copy the embbed code and paste into the html editor but the error message appear..
So, how can i get the widget appear without the "get widget"font appear?
Hope i can get help on this..
my site=http://mrhsite.synthasite.com/..
Thanks.
Photo of Wan
Wan
  • 1 Post
  • confused
Photo of Marije
Marije, Official Rep
  • 4636 Posts
  • 237 Reply Likes
Official Response
Hi Wan,
The phrase, or tag "get widget" is part of the terms and conditions that you agreed to when you got the code for the widget from Widgetbox.
Think of it this way: you are getting a great looking widget for free, in return the developers would like your friends to know where you got it from, so that they can get one too. If you wish to delete the words "get widget" from your widgets you should contact the widget designers or the support staff of the widget service involved.
Other widget services can have less prominent signage on their widgets, you can always search for a different service. Once you've got the HTML code to add to your site, you can use the HTML widget:
1. Drag-and-drop an HTML widget from the sidebar on the right onto your page (the icon for this is a blue sphere).
2. An HTML editor will open up that will allow you to write or paste your code (use right-click > paste or ctrl-V to paste).
3. When you are done, click "OK" and your HTML will be displayed on the page.
Please let us know if you have any other questions.
