WWW. NEED HELP!
  • Updated 10 years ago
how do i get my allreadybought domain name onto synthasite ?? ohh and i cant point it coz it doesnt work i have a password if that helps!!
Photo of Dill Shellard
Dill Shellard
  • 142 Posts
  • 3 Reply Likes
  • frustrated
Photo of Ruth
Ruth
  • 2819 Posts
  • 135 Reply Likes
Hi Dill,
Can you tell me who you purchased your domain name from? You will need to point it to SynthaSite.
If you have forgotten your password for your domain name registrar then you will need to contact them for assistance.
How to configure a domain name you already own:
1. Log in to your chosen domain registrar (eg. Crazy Domains)
2. Go to the DNS Management page.
3. Set up an A Record
4. The IP address of your record must point to: "208.75.208.172"
Please note that it can take up to 48 hours (although usually less) for these changes to take effect. Your domain name registrar should be able to help you out in this regard.
For more information, please see this tutorial: http://www.synthasite.com/tutorials/p...
Dill Shellard
  • 142 Posts
  • 3 Reply Likes
i know the password but do not know what it was bought on as it was given as a present! i also have the password!
Photo of Ruth
Ruth
  • 2819 Posts
  • 135 Reply Likes
Hi dill,
Perhaps you could ask the person who gave you the domain name to make the changes for you. Unfortunately, this is the only way for you to use your domain name with SynthaSite.
It needs to point to our IP address.
Dill Shellard
  • 142 Posts
  • 3 Reply Likes
realy how come??
Photo of Monique
  • 6294 Posts
  • 446 Reply Likes
Tell us what the domain is. We can use the whois database to find out where you bought it from: http://www.whois.net/
Dill Shellard
  • 142 Posts
  • 3 Reply Likes
Photo of Emmy
Emmy
  • 5892 Posts
  • 299 Reply Likes
Hello,
I see that the domain was purchased from: http://www.heartinternet.co.uk so please login to your account here and follow the instructions that Ruth posted above. Let us know if you have any problems.
Regards,
Emmy
