Yola Branding Going to Top Front of my Page
Good Day i have a question im using template no frills and i put a code when im preview the YOLA Branding going to top in front of my page how to fix this?? Thank You
Photo of Jonathan M. Guevarra
  • 33 Posts
Photo of jeremy
jeremy, Employee
  • 1349 Posts
  • 90 Reply Likes
Hello,
Are you referring to the Yola link at the bottom of your page?
Yola offers you the option to remove the Yola Link as part of the Yola Silver package.  If you upgrade your account to Yola Silver, the Yola Link will be removed from all the sites in your account.
To learn more about everything included in the Yola Silver package, see: Yola Silver FAQ.
I hope this helps.
  • 2582 Posts
  • 279 Reply Likes
This sounds to me like a frequent little pest that sometimes happens when you place a code you find from somewhere else on the web onto your page and it overrides the positioning of the Yola footer or breaks the page layout.
When I was just beginning to build my site it happened often and one day I found that if you use a two column widget you can lock the code from interacting with other codes on your pages.
Give this a try as it may just work in your case as well.
1) Copy the code from the HTML widget that affected your Yola footer.
2) Delete the HTML widget that contained the code from step 1
3) Click the "Refresh your page" button in the Yola sitebuilder toolbar and in the pop-up click the "Yes" button.
4) Drag a two column widget divider from your right toolbar onto your page.
5) Drag a new/blank HTML widget onto either the left or the right side of the new two column divider from step 4 and paste the code that you copied from step 1.
6) Click the "Refresh your page" button in the Yola sitebuilder toolbar and in the pop-up click the "Yes" button.
7) Click the "Preview" button to view your site and see if the Yola footer has returned to the bottom of the page where it belongs.
Not saying that this will for sure fix every situation that breaks the page layout but it usually 90% of the time will return objects to their proper place... ;)
Call it placing a bad code in a jail cell of sorts. ;)
Happy site building
Ed
If the lady bears don’t find you handsome they should at least find you handy...Please share my website with your friends online....
Honey Bear Playhomes Tips and Favs in one place... A Honey bear Playhomes Tip ;)
