Yola Shop not adding Products
I added my products to the Yola Store but when I try to use them on the site they don't show up and it says no products added. I go back and check and everything is saved, but it still says no products.
Photo of tiarasntreasures
tiarasntreasures
  • 1 Post
  • frustrated
Photo of Gop
Gop
  • 7473 Posts
  • 2115 Reply Likes
Hi T&T,
It may be worth checking the inventory of products.
Online Store → Advanced settings → (System Settings) → Catalog → Products.
if you confirm that they are in your inventory then drag the Online Store widget onto your store page from the fr right hand side, select the Category of products youwish to display and the configuration of the style of display. That will then place your selected products on the page.
If there are problems with this I'm happy to work with you to solve it.
